toner for proc900s
  • en.
    • Jul 2014
    • 124
    toner for proc900s
    hi sir
    there are missing toner for ricoh proc900s in our location ...can i use toner for ricoh pro5100s i mean refill from 5100 to proc900s
    is there any sp mode can i change or its give problem with development unit
    best regards
  • sandmanmac
    • 3964
    Re: toner for proc900s
    Originally posted by en.
    hi sir
    SURE!....just set SP5555 "Any old toner will do" to "1" (on)
    • Tonerbomb
      AutoMajical Resolutionist
      • Feb 2005
      • 2589
      Or was it SP 666.......................
      Mystic Crystal Revelations
      • sturmtrooper
        Copier Combobulator
        • May 2016
        • 587
        I would NEVER put toner from a different model into another machine... the developer is different the toner formulation is also different.. you are just asking for trouble doing that.
        I kinda want someone to do it to document the carnage.
        • anothertech
          • 1756
          If you change the toner, you need to change to the 5100 developer also, be sure to set SP5555-02 any old dev will do to "1" (on)
          Remember, always match the toner with the developer.
