savin c3030 paper jamming in finsher
  • okcopier
    • Dec 2011
    • 13
    when I am running copies without the finisher connected it runs without jamming but when I connect the finisher up and run a print job it jams as soon as the paper goes into the finisher. can someone help me on this?
  • LNorris
    • Sep 2008
    • 645
    Re: savin c3030 paper jamming in finsher
    what kinda of finisher? does it have hole punch as well?
    • okcopier
      • Dec 2011
      • 13
      it the SR 790
      • Onomono
        • Oct 2016
        • 6
        Is the paper accordion-ing in the finisher or miss-feeding?
          • 37533
          If the jam code is J100 and the machine has been recently moved, like just before it started jamming, check the bracket that the entry guide mounts to. Customers will use the entry guide as a grip point and deform the mount, guide or both. This will cause either the upper or lower entry roller, depending on which is not the one driven by the drive belt, to nit be in contact with the driven roller. I have also seen the gap between the guides at the roller to be moved to where the paper hit one roller or the other and not where they come in contact.
          If it is not J100, check the transport sensor in the bridge unit.
          • Iowatech
            Not a service manager
            • 3930
            If time permits you might want to clean and relube the bushings for the rollers in the finisher. At least if there appears to be some sort of black looking goo on them anyway.
            And on a lighter note, you may want to pay attention to the area where the finisher gets plugged into the MPC3030. Occasionally if people like the users of that machine get in a hurry when moving the machine, they may accidentally smash that connector.
            • jonhiker
              • 661
              Also, clean all of the entrance rollers. They star out as gray, but end up black. This works well for jams in going into the upper tray.
