Ricoh MPC 5502 SC553
  • semi
    • Sep 2008
    • 193
    [Electrical] Ricoh MPC 5502 SC553
    Managed to trap a lamp wire whilst changing the sleeve,blew the mains,machine powers up fine,SC553-swopped with good fuser,still the same,what do reckon,new IOB or themoplies?Hv board fuses ok
  • sturmtrooper
    Copier Combobulator
    • May 2016
    • 587
    Re: Ricoh MPC 5502 SC553
    Ignore the Italics I was incorrect.
    The thermopiles are part of the fuser, if that was the only problem the fuser swap would have fixed your code.
    Since the codes states it's an overheat error could be your IOB is not telling the fuser to turn off.
    I don't believe the HV board is used in the fusing circuit. Not sure though.
    • ABS tect
      • Sep 2013
      • 511
      Did you do an SC reset? SP-5-810? Sometimes you just have to clear the code.
      • semi
        • Sep 2008
        • 193
        Reset SC code,tried a new fuse as well on the sleeve,get failed result on 5810-2,I've ordered the IOB
        • TonerMunkeh
          Professional Moron
          • 3865
          Eh? I thought the thermopiles were on the machine frame?
          Hit it.
          • sturmtrooper
            Copier Combobulator
            • May 2016
            • 587
            thermopile.pdf
            I rechecked and you are correct. The first picture I looked at made it appear the thermopiles are attached to the fuser.
            • TonerMunkeh
              Professional Moron
              • 3865
              Having checked the parts catalog I at first assumed the thermopiles were small trumpets that play a fanfare when a fuser code is reset.
              Hit it.
