Hello everyone,
I have an SR5000 (B830) finisher on a 1306ex which has never really had any major issues just broken staple cover rear, and shift tray lift motor failures which seem to be pretty common in this one. Recently however I have a customer that runs a large job daily that is sorted every 3-10 sheets so its constantly shifting, the nice little stack arms are always goofing up but that doesnt seem to bother to much, mainly for some reason after the first set comes out and the tray shifts the first and second sheet come out dang near at the same time, the first sheet barely hits the tray before page 2 is landing on it, whats happening is that page 2 is pushing the first one almost off the tray there isnt enough time between the sheets for the first one to land and be pulled to the stack by the foam rollers (which are new rollers) so every set is messed up, when 1000 pages are stacked it looks like someone just threw the stack on there, pages are sticking out all over the place.
I have seen 1 or 2 sheets sometimes not fall in line but in the last few weeks its doing this all the time. I am not sure how to correct this as it looks like its just timing between page 1 and 2, after page 2 comes out the rest of the pages in that sort have perfect timing until it shifts and kicks out the first 2 sheets again. Like i said what this customer prints is a few sheets then shift, few sheets then shift anywhere when the job is complete there are 300-1000 pages on the tray with about 200 shifts.
I have also noticed the shift tray makes a lot of noise when it shifts front or rear its slapping hard dont know that i have ever noticed it to be as loud as it is now, but i dont see any loose belts or the shifting motor/cam to be worn, i know sometimes the shift motor bracket gets worn and becomes sloppy.
I have run into some J112 jams also that i think are stepper motor related, so I am thinking of replacing 2 stepper motors and the 2 drive motors and replacing all the pulleys along the timing belts. the machine has over 10 million on it and they use the shift tray for 99% of the jobs they run.
I am wondering if anyone has any tips on the stacking, i dont know if the tray angle deforms over time or if the side brackets wear out, also any tips on the stack arms those things seem to kick on an off willy nilly today they were actually not coming down and just slapping backwards against the top cover. Anyone ever modified the rear staple head cover so it doesn't break every 10k staples. Also not sure which motor they consider to be transport motor, goose guides says j112 is the transport motor but i can see 4 motors that all drive belts to transport paper one way or another.
thanks in advance for any tips.
