Mp 6002 - ld 360 toner hopper
  • Hoosierdaddy
    • Oct 2016
    • 182
    WHAT CAN BE DONE TO STOP THEM FROM SPRAYING TONER FROM THE HOPPER ASSEMBLY? EVEN DROPS TONER WHEN OPENING TO ACCESS TONER BOTTLE.
    THANKS HOOSIERDADDY
  • LNorris
    • Sep 2008
    • 645
    Re: Mp 6002 - ld 360 toner hopper
    there is a tech bulletin from 6/2014 you might want to look at.
    • Hoosierdaddy
      • Oct 2016
      • 182
      I will look at that.
      Thanks hoosierdaddy
      • Hoosierdaddy
        • Oct 2016
        • 182
        That doesnt seem to be what mine are doing. It looks like a seal or something like that in the toner hopper assembly itself.
        • mikadonovan
          • May 2008
          • 2931
          I've experienced this on every Ricoh with this type of toner delivery system since the 6645 (A096). Clean the cup out frequently and keep a wiper handy for the spills right below it. SOP for Ricohs. The B003 series was worse than this model for toner spills.
          NEVER ASSUME ANYTHING
          • sturmtrooper
            Copier Combobulator
            • May 2016
            • 587
            I don't believe that relates to leaking at toner hopper.
            • Chicko
              • Sep 2015
              • 36
              Bit of a common problem this. I agree with the other techi who said clean the cup out. Normally what I do every 200k copies or so is remove the entire hopper unit , empty everything into a bin and then completely vacuum everything.
              This reduces the spills and keeps everything clean, which is also important for the motor that drives the toner bottle. The last thing you want is that motor to stop working just because of a simple clean up.
