Pro C651Ex Print Option ?
  • Elmo
    • Feb 2010
    • 541
    Hi All
    Can anyone help
    just recieved a used Pro C651 Ex but the Fiery did not arrive with it
    does it have print installed as an option for use without a fiery
    or do i need to get an sd with the option on
    or do i need to get a fiery to print
    i have changed the sp controller option to no external fiery
    but cant find any sp mode to disable enable option for print
    I Used To Live To Fix Things Now i Fix Things To Live
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Pro C651Ex Print Option ?
    How many NIC's are there in the controller? That's the usual way to find out whether it's capable of GW printing.
    Hit it.
    • Elmo
      • Feb 2010
      • 541
      It has 2 x Nic 1 on board and an optional 1 fitted
      • TonerMunkeh
        Professional Moron
        • 3865
        Is SP 5985 for the NIC enabled?
        Hit it.
        • Elmo
          • Feb 2010
          • 541
          Yes nic and usb enabled
          the scan option is there just no print option
          • khattab.al.masry
            • 212
            Check the following sp 5-193 (External controller information setting):
            This SP selects the controller type. This setting needs to be done if an external controller is
            Installed in the machine.
            [0 to 6/0/1]
            0: No external controller installed
            1: EFI controller
            2: Ratio controller
            3: Egret controller
            4: GJ
            5: Creo
            6: QX-100
            • anothertech
              • 1771
              So the bottom line is, no there is no build in print function, you need an external controller.
                • 37532
                From the service manual:
                • Although this machine also has the GW controller, there are no GW printer applications. All printing features are provided by the Fiery E-41A external controller.
                • The D074/D075 is equipped with both GW and Fiery scanner functions. Both features are available at any time when the GW and Fiery controllers are connected via the same network.
                There are 2 network jacks. The gigabit jack is the EFI fiery port. The other, the one directly below the USB(for Japan) port is for WIM and @Remote.
                • info@digitaalprint.be
                  • Aug 2016
                  • 33
                  The first series of PRO C651 CANNOT print without Fiery. It is only from a year after the first production that it is possible via PCL
