MPC3300 second paper drawer issue
  • digicor
    • Jul 2008
    • 1159
    Hey maybe some can help with this, I have a second paper drawer that intermittently does not pick up the paper, i have changer out the feed tire's the reverse rollr clutch and the paper pick up feed clutch
    is there a common problem somewhere on these? I do have another in the field that i never hear a peep from...
    thanks
  • tonnerboy
    • May 2011
    • 212
    Re: MPC3300 second paper drawer issue
    Hello.
    I suggest you to check the entire feed unit.
    It has happened to me several times the need to clean it all and lubricate the bearings...
    • digicor
      • Jul 2008
      • 1159
      ok thanks, and if i may ask , do you deal with the return cable thats spring loaded on the back side of the inside of the duplexer? to remove the paper feed mechanism, it seems this must be delt with right?
      • zed255
        How'd ya manage that?
        • 1024
        There's a latch to hold the duplexer cable spring allowing the cable to be unhooked from the main machine. Undo the front stopper, let the duplexer down further than usual, reach under the bypass and activate latch, raise up duplexer to rest the spring on latch. No hard once you realize the latch / catch is there.
        There is an updated bushing that is longer than the original in the feed assembly. If you press the pickup arm release and see if the arm has unusual free play, if so either update the bushing or replace the assembly.
        • digicor
          • Jul 2008
          • 1159
          thanks
          • LNorris
            • Sep 2008
            • 645
            check the tray itself, the latch that holds the tray in, may be broken and letting the tray back out.
            • zed255
              • 1024
              See the attached from the service manual:
              Duplex Removal.pdf
              Also bulletin for the bushing:
              rfg052561.pdf
                • 37532
                Things that I have encountered with paper feed tray no feed:
                1. Sheet of paper with corners bent under so that the back lead edge of the paper is lifted higher than the center.
                2. Paper lift plate is warped.
                In either of these cases, the paper at the back lifts the paper sensor before the paper is touching the pickup roller.
                • digicor
                  • Jul 2008
                  • 1159
                  thanks for the info on this, it just may be this bushing you speak of.
                  • NeoMatrix
                    Senior Tech.
                    • 3513
                    How are the vertical guide plates ?
                    Are the tabs broken off the guide plates ?
                    D0092836
                    GUIDE PLATE
                    125.D0092841
