Hi all, i have a problem with my ricoh aficio copy is very light. I changed drum units, transfer clean laser and nothing changed. I changed paper trasnsfer roller and nothing change. ONE THING VERY CONFUSE ME. I TRAY TO MAKE COPY WITHOUT TRANSFER ROLLER AND NO CODE COME UP or when i forced with somthing paper transfer roller to be closer to transfer the copy is a litle bether.SO I STARTED TO THINK THAT ELECTRICITY IS PROBLEM. If anybody find solution please helpThanksRegards
Ricoh mp c4500 fade copy
Re: Ricoh mp c4500 fade copy
I dont have pictures right now, but you can see the pictures that another member posted on diferent thread
http://www.copytechnet.com/forums/ri...deficient.html
My copy is same like his pictures
RegardsComment
Had a similar problem recently. Customer called for light copies but said the machine printed OK. Printing the Counter Page showed that copies and prints were both light. Looking at the lower display it showed all 4 toner cartridges at FULL. This machine was an older C3000 (the chances of all four cartridges being full at the same time are slim). Further investigation showed that a prior tech (also, no longer with us) had turned SP 3045 (Toner End Detection to 1 - which is OFF). Basically, the machine was starved for toner, but couldn't signal it was out of toner. You may want to check this (the same tech did the same thing on another machine to me so this call did not take me by surprise).Comment
have you cleaned the ID sensors and run process control, what your PMs at for developer recommended 160k most go way over that. I know they say the transfer belt should last as long as the machine but the machines lifetime is like 1 million if your over that then most EM parts are past their lifespan. On these models poor voltage i usually see things like stripes, digitized images, shading of the page. I dont get many that are free of any other defect besides faded out as a voltage issue, usually its worn out PM parts, and cleaning.Comment
