c8002 with sc442
  • T911
    • Jun 2007
    • 628
    c8002 with sc442
    can't get rid of this code. replaced lift motor and lift home sensor any ideas thanks
  • semi
    • Sep 2008
    • 194
    Re: c8002 with sc442
    You need to replace this motor D1361212 DC Motor ON/OFF TRANSFER ASS'Y
    It's buried under the magenta PCDU drive ass'y
    • Itanic
      • Dec 2014
      • 59
      Did one of these today! Starting to see more :-(
      As semi says D136 1212 is a modified motor inc wormdrive. The service manual does not show the location of this motor or how to change it! Managed to locate / workout from the parts list!
      There is a recent RTB / TSB for this issue when they issued the newer modified motor part RTB No. RD135168a
      A previous thread on the forums mentioned replacing the other 2 gears inside the gear casing but now the new motor is available i dont see the point of replacing those anymore!
      I took a photo to show my boss (attached)... Takes about an hour or so to get it done.. need to remove the iob, 2 black plastic fan ducts (1 of which is behind a metal frame runing horizontally and has wiring loom attached)..
      Then the itb lift motor casing is a black plastic case with two screws..20161117_150116 (Small).jpg
