MP 2001 Not Working
  • mtebka
    • Dec 2013
    • 38
    [Electrical] MP 2001 Not Working
    Hi guys. Got an MP 2001 that is not responding. When I turn on the main power switch the main power indicator is on and the operation panel is off. The machine is not running at all. Could this be a defective BICU or Power Supply? Need your help before I order the wrong part. Thanks in advance.
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: MP 2001 Not Working
    Could also be the controller. Disconnect all the options, check the fuses on the PSU.
    Hit it.
    • mtebka
      • Dec 2013
      • 38
      I have done that to no avail
      • TonerMunkeh
        Professional Moron
        • 3865
        Then unfortunately it's a bit of a guessing game. PSU would be the likely bet but you'll have to order all 3 parts, PSU, controller and BICU. Could also be the DCSW board that sits on the PSU.
        Hit it.
        • Mark Bbb
          • Jun 2012
          • 1662
          in such cases it helps when you get some more info:
          was there a power breakdown before it happens?
          When did actually this problem occur and what were the conditions then:
          was it printing when it happens, or just by putting it on in the morning?
          etcetera...
          • tnelson
            • Aug 2016
            • 21
            i know the color copiers (c2000 c2500 c3000 c2800 c3300) have issues like this. the polygon motor in the laser malfunctions and takes out the bicu. i have had to replace these as a set multiple times now. if you shine a flash lite at the screen you can sometimes see the sc code on the screen even though its dark.
            • mtebka
              • Dec 2013
              • 38
              Hi guys. I fitted the BICU and power supply. The machine came up with SC 101. I have put the scanner assembly and NVRAM in another machine and it is working fine. What could it be now
              • Polarbear
                • Feb 2012
                • 1070
                Soon after the MP2501 launched here in South Africa, we received one that had the same symptoms out of the box.
                We needed to replace the BICU (if I remember correctly).
                Was this machine working before?
                Press the GREEN button!!
                • Polarbear
                  • Feb 2012
                  • 1070
                  Please check that all the connectors are fully inserted, and in the correct sockets.
                  Can you enter SP mode? Check all the sensors via SP 5-803 (input check) to make sure it is not a faulty sensor that is causing your headache.
                  • Mark Bbb
                    • Jun 2012
                    • 1662
                    So, did you finally get it back to work?
                    • mtebka
                      • Dec 2013
                      • 38
                      This is a brand new machine. I fitted new BICU and it came up with SC 101. The power supply and scanner assembly are working in the other machine. I have ordered new NVRAM. Funny thing though is that the NVRAM is working on the old machine. The new machine is working if I put the BICU from another machine.
                        • 37556
                        If as you say it is a brand new machine it should be replaced under warranty. Stop f**king with it.
                        • mtebka
                          • Dec 2013
                          • 38
                          Ricoh does not replace PCB's under warranty. I am not sure if I stand to be corrected.
                            • 37556
                            Out of box failures they replace the entire machine.
