Hi guys. Got an MP 2001 that is not responding. When I turn on the main power switch the main power indicator is on and the operation panel is off. The machine is not running at all. Could this be a defective BICU or Power Supply? Need your help before I order the wrong part. Thanks in advance.
MP 2001 Not Working
Tags: None
Re: MP 2001 Not Working
Could also be the controller. Disconnect all the options, check the fuses on the PSU.It's 106 miles to Chicago. We've got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
Hit it. -
Then unfortunately it's a bit of a guessing game. PSU would be the likely bet but you'll have to order all 3 parts, PSU, controller and BICU. Could also be the DCSW board that sits on the PSU.It's 106 miles to Chicago. We've got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
Hit it.Comment
in such cases it helps when you get some more info:
was there a power breakdown before it happens?
When did actually this problem occur and what were the conditions then:
was it printing when it happens, or just by putting it on in the morning?
etcetera...Comment
i know the color copiers (c2000 c2500 c3000 c2800 c3300) have issues like this. the polygon motor in the laser malfunctions and takes out the bicu. i have had to replace these as a set multiple times now. if you shine a flash lite at the screen you can sometimes see the sc code on the screen even though its dark.Comment
Soon after the MP2501 launched here in South Africa, we received one that had the same symptoms out of the box.
We needed to replace the BICU (if I remember correctly).
Was this machine working before?Press the GREEN button!!Comment
Can you enter SP mode? Check all the sensors via SP 5-803 (input check) to make sure it is not a faulty sensor that is causing your headache.Press the GREEN button!!Comment
This is a brand new machine. I fitted new BICU and it came up with SC 101. The power supply and scanner assembly are working in the other machine. I have ordered new NVRAM. Funny thing though is that the NVRAM is working on the old machine. The new machine is working if I put the BICU from another machine.Comment
