Mp 6500
  • andywong90
    • Mar 2013
    • 110
    Mp 6500
    Can anyone help me how to solve sc220.thanks
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Mp 6500
    220 Laser synchronization detection error B246
    The 1st laser synchronization detection unit could not detect the line synchronization signal (DETP0) within 500 ms while the polygon mirror motor was operating at normal speed. Note: The unit polls for the signal every 50 ms. This SC is issued after the 10th attempt fails to detect the signal.
    • Laser synchronization boardconnector loose, broken, defective
    • Laser synchronization detection board is not installed correctly (out of alignment)
    • Laser synchronization board defective
    • IPU defective
    Also could be the poly mirror, laser emitter or door switches.
    Hit it.
    • andywong90
      • Mar 2013
      • 110
      Re: Mp 6500
      Ic,like that what should I do,or change laser assy for testing see how? Laser can repair or not?
      • anothertech
        • 1756
        Re: Mp 6500
        Try cleaning the beam detect sensor.
        • bat
          • Sep 2008
          • 138
          Re: Mp 6500
          I had few of these machines on field, with blown polygon motor causing SC220.
          • Zoran
            • 44
            Re: Mp 6500
            Replace laser diode for aficio 1060 to mp
            • Codex
              • May 2008
              • 694
              Re: Mp 6500
              Can i fix the 1060 diode to an Mp6000?
              Inviato dal mio SM-G935F utilizzando Tapatalk
              Memento Audere Semper
              • Zoran
                • 44
                Re: Mp 6500
                yes , replacing the diode complete with aluminum housing
                • Codex
                  • May 2008
                  • 694
                  Re: Mp 6500
                  You tried it on an Mp6500 and Mp6000?
                  • Zoran
                    • 44
                    Re: Mp 6500
                    yes
                    • Xeroid-ex
                      • Mar 2020
                      • 2
                      Re: Mp 6500
                      Where is that I haveva manual and cannot find it
                      Sent from my SM-T510 using Tapatalk
                      • mikadonovan
                        • May 2008
                        • 2931
                        Re: Mp 6500
                        This thread is 3 years old, you might want to start a fresh one. 90% of the time a sc220 is caused by a failed polygon mirror motor ( inside the LD assembly).
                        NEVER ASSUME ANYTHING
                        • fshead
                          • 2356
                          Re: Mp 6500
                          A lot of the times you can see the components on the board that got fried and burnt copper traces too..
                          To me a lot the times you can see if earlier or latter models will fit..
                          at worse you waste time checking..
                          I havent saved my last mp6500/mp6001 trade ins as time was not there for it...Otherwise i would offer up some cheap
                          options..
                          • Xeroid-ex
                            • Mar 2020
                            • 2
                            Re: Mp 6500
                            Wow thanks for the speedy reply where is the best place to pickup parts? I am an ex Xerox tech I got this machine for Free So I am fixing it up and going to donate it some place who can use it
                            To be certain it's the motor I could go in the input out put and turn it on and I should hear it rather than strip the machine down that faar
                            • farhad
                              • Apr 2020
                              • 40
                              Re: Mp 6500
                              1.check you machines doors swich
                              2.check you machine LD sensor upper side on bypass
                              3.change you LD unit
                              4.check connector on control board and main board
