Ricoh mp 306 error sc 554
  • tibbs
    • Aug 2008
    • 225
    Hi, I have two mp 306 with error sc 554 I have changed the fusers but the problem is still there.
    Can anyone help.
  • copier tech
    • 8130
    Re: Ricoh mp 306 error sc 554
    Can anyone help.
    After replacing the "fusers" did you reset the error with SP5810 ?
    • tibbs
      • Aug 2008
      • 225
      Yes I did reset the error with sp5810. Same problem.
      • Brianneoe
        • May 2015
        • 318
        5.6.15 SC553-00, SC554-00Error Name
        SC553-00: Fusing Thermistor (End) High Temperature Error (Software)
        SC554-00: Fusing Thermistor (End) High Temperature Error (Hardware)
        Type
        A
        Symptoms
         SC553-00
        or more, when the relay is activated at power ON/ recovery from Energy Save/ rotation
        after reload/ before or during or after paper feed/ standby/ energy save/ low power mode.
         SC554-00
        activated.
        Possible Causes
         The triac has short-circuited.
         The BiCU is defective.
        Troubleshooting Procedures
        1. Reconnect the connectors (main machine, BiCU).
        2. Replace the thermistor.
        3. Replace the fusing thermistor harness inside the main machine.
        4. Replace the BiCU.
        If the problem cannot be solved after performing the above steps, replace the fusing unit.
        Good Luck
