M p 6001 indicator light
  • andywong90
    • Mar 2013
    • 110
    Hello guys,anyone cab share me what problem with my machine. Problem is...
    While start on machine,wait awhile to press indicator light,itjust blinking does not want turn off.after that open feeder and close down then press indicator light,it will turn off.
    It normal,right?
    One thing I can't understanding to fix is ,turn on machine.u press indicator light, it blinking around 20 sec then automatic turn off.after u make a copy, copy sheet, 2 sheet or more,pressing indicator light does not off,however u open close feeder many times.anyone can tell me why?
  • Polo-022
    • Sep 2007
    • 486
    Re: M p 6001 indicator light
    Everything is normal...you cannot switch it off if : ADF is open, toner is empty, prints through network have just arrived, etc...
    i guess you have enough time to polish your screwdrivers...
    • andywong90
      • Mar 2013
      • 110
      Fren,I mean indicator switch does not turn off is...
      On machine, wait awhile,then press it.indicator light will auto off.that situation is normal.
      But after I make copy let say 1 sheet 2 sheet...
      Press indicator switch, it become blinking does not turn off.wait a long time still flashing. What wrong wit this machine? Open adf then put down again still same..
      Hope guys can explain & help me solve it.thanks
      • sandmanmac
        • 3983
        Why are you starting a new thread about the same issue!? And what's the big deal anyway?!!
        http://www.copytechnet.com/forums/ri...mp-6001-a.html
        ...And why do you seem to be posting a new thread almost every day about every little thing that happens with this machine?
        http://www.copytechnet.com/forums/ri...rol-panel.html
        http://www.copytechnet.com/forums/ri...-firmware.html
        • andywong90
          • Mar 2013
          • 110
          I almost post same issues cases because this machine mp 6001 make me crazy to fix it.guys can help me
          • anothertech
            • 1771
            If you think it's ok to start multiple treads, you are wong.
              • 37553
              That and always asking for something. Never contributing help to anyone.
