RICOH SP305SPF
  • printertnc
    • Jun 2015
    • 68
    RICOH SP305SPF
    Buonasera
    Ho una Ricoh RICOH SP305SPF configurata e installata al cliente a Settembre2016
    A distanza di due mesi ogni tanto compare l'errore SC452, ho controllato e tutto sembra essere ok.
    L'errore si presenta RANDOM, quale pezzo devo sostituire?
    Il rullo di trasferimento Carta, o il rullo di trasferimento?
    Grazie
    Good evening
    I have a Ricoh RICOH SP305SPF configured and installed at the customer Settembre2016
    A two-month away every now appears the SC452 error, I checked and everything seems to be ok.
    The error occurs RANDOM, which piece should I replace?
    The transfer roller paper, or the transfer roller?
    Thank you
    • 37510
    • copier tech
      • 8164
      Re: RICOH SP305SPF
      I have this exact same issue, on mine when the customer clears a jam they don't close the door firmly enough at the rear, then the PTR retraction motor cant drive the PTR unit & throws SC452.
      You may want to check that.
      • printertnc
        • Jun 2015
        • 68
        Re: RICOH SP305SPF
        Attention
        On Manual
        SC452
        Paper transfer belt contact motor error
        The paper transfer belt contact motor drives beyond the specified time during
        home position detection or contact operation.
        • Broken harness or defective connectors
        • Disconnected connector of paper transfer belt contact sensor or motor
        • Defective paper transfer belt contact motor
        • Paper transfer belt unit not installed
        1. Check and replace the harness and connectors.
        2. Replace the paper transfer belt contact motor.
        3. Reinstall the paper transfer belt unit.
        Can i replace paper transfer belt?
        • bpred
          Re: RICOH SP305SPF
          Just a comment to old thread.
