Ricoh MP 3010 lines
  • didi2005
    • May 2011
    • 401
    Ricoh MP 3010 lines
    Print counter list with lines. Replaced drum & blade, problem still exists...Is it charge roller problem?
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Ricoh MP 3010 lines
    More than likely, or hot roller. When you're replacing parts in the PCU, change them all including developer.
    Hit it.
    • didi2005
      • May 2011
      • 401
      Is charge roller problem...after wipe the stripes on charge roller, no more lines...
      • sturmtrooper
        Copier Combobulator
        • May 2016
        • 587
        You are better of changing the roller. Those lines will probably be back in a few days or weeks.
        • didi2005
          • May 2011
          • 401
          You're right...After 3 weeks the lines strike back...
          This time really need to replace the primary charge roller...I wonder what is the cause of the stripes?
          • copyaction
            • Oct 2007
            • 991
            The total count on this is 22?
              • 37532
              Depending on how soon the lines come back and if they are always in the same place, there may be small nicks on the cleaning blade.
              I have also seem a clog in the toner recovery cause this
