savin MP2852 jam problems
  • alliedofficeproducts
    • Jan 2015
    • 92
    [Jamming] savin MP2852 jam problems
    Hello everyone. Having a time with this one. The paper seems to be jamming mainly before the finisher but sometimes in the paper exit assembly and is intermittent. Doesn't matter if it is single side or duplex prints/copies.
    • 37560
    Re: savin MP2852 jam problems
    And the Jam Code is???
    • Counsel
      • Aug 2011
      • 529
      Internal finisher? Side mounted? The side finsher will have a bridge unit which can have faulty push switches or dirty sensors. The internal one could be several other things. The jam code would help.
        • Jan 2015
        • 92
        It is a side mounted finisher. I changed the output for prints and copies to internal tray 1 to eliminate the finisher and that is when i noticed that the problem seemed to actually start before it got there. It must be my old age but I totally forgot to write down the jam or service code before posting. Truly sorry about that
          • 37560
          If you are getting a J001, replace the door switches on the bridge unit.
            • Jan 2015
            • 92
            Thanks, I will check that first when I get back out there tomorrow. Next time I'll make sure I have all of my info before submitting.
              • Jan 2015
              • 92
              I found a loose sensor in the bin assembly. It appears a previous tech tried to repair this problem before by using electrical tape instead of replacing the bin
              Sent from my LGL41C using Tapatalk
