Ricoh C6502 - 402-54
  • Stormhammer
    • 150
    Ive been working on this machine for a few days now and it has the SC code listed in the title. I replaced the developer as the manual suggests and no go. I had someone suggest replacing some rollers on the ITB like the bias roller and did that and no go. What could this possibly be? The power pack? The LD unit?
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Ricoh C6502 - 402-54
    Next step would be dev unit, it's a gamma output error.
    Hit it.
    • Stormhammer
      • 150
      Youll have to pardon my ignorance on the subject but in what way would the dev unit be defective?
        • 37533
        Defective TD sensor. Broken gears on the paddle shafts, Broken paddle shafts. Just to mention a few that I have had in the past.
        • Stormhammer
          • 150
          I boiled it down to the yellow pcdu at least from sp 3012-001. So i should replace the whole dev unit at this point? I dont think theres anything else to check, really.
          • Stormhammer
            • 150
            I believe i found my smoking gun. Swapping the td sensor made the machine change error states. Turning off gamma correction allows the machine to print albeit a bit light. The TD sensors seem to be at the heart of the issue.
            • Stormhammer
              • 150
              Replacing the potential sensor that sits above the PCDU solved this as I suspected it would. A shame I spent and entire shift driving there and back.
