Hi All- our C4503 has the single pass doc feeder (can scan doubled sided with one pass) and I'm having an issue with skew on feeder scans and copy's.
Pics worth a thousand words, so check the attached PDF. I guess you'd call it the trailing right edge is lower than it should be by about 3mm. The leading right edge is similarly "pulled" down about 3mm more than leading left edge. I marked up the pdf scan to better explain, but let me know if there are questions.
Maybe to make things a little more confusing, the line artifiact only shows up during scans, not when copying from the feeder.
I've tried adjusting some SP settings, namely in SP6-006 and SP4-008+ but haven't hit the right ones. Starting to wonder if this is a mechanical issue with the feed unit.
Thanks for suggestions.
PS- scanner counter shows about 26,000, so relatively 'fresh'.
