jam - sc 720-081
  • tavorh
    • Sep 2016
    • 25
    jam - sc 720-081
    i've problem with machine mpc4502. Offten machine shows jam and then sc720-081, conect the finisher SR3110. Anyone had this case?
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: jam - sc 720-081
    Firstly, does it actually have a finisher attached to it? If not, remove the bridge unit, replace with an output tray, and set the paper output to the internal tray. If it does, check the finisher connector and plug for damage, have known these connectors to get damaged in the past.
      • 37556
      Normal for Ricoh. The first time a error is detected with a finisher, it is shown as a jam. Clear the jam and if the same error is immediately detected it then show the Service Code for the error, in this case SC 720-081, Paper position sensor slide motor error.
      • tavorh
        • Sep 2016
        • 25
        Maybe you know which sensor is this on sr3110?
        • DougD
          2020 Retired
          • Sep 2016
          • 76
          I would pull the punch unit out, vacuum out all the chads and check that everything is moving freely.
          The error is coming from the punch unit.
          • Imprestik
            • Aug 2012
            • 297
            Yes I just had this the other week.
            Your hole punch unit is toast, replace it
            • emtdavis
              • Nov 2015
              • 6
              Same error here - a paperclip was preventing the hole punch from initializing/getting to home position. After fishing the clip out, all finisher functions resumed.
                dead thread
