Ricohs and wireless
  • mikadonovan
    • May 2008
    • 2931
    Ricohs and wireless
    Hi All. I think I read somewhere on the forum that some have used a wireless router of some sort instead of the wireless adapter offered by Ricoh for LAN connection. If you know something about this, could you give me the particulars? Thank you.
    NEVER ASSUME ANYTHING
  • mikadonovan
    • May 2008
    • 2931
    Re: Ricohs and wireless
    Never mind, I found it. Have a great Christmas, everyone.
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3944
      Good call on ditching the Ricoh wireless card.
      It's expensive, and not very reliable.
      If the signal strength dares to dip to 60% or lower, count on it going offline.
      If you have @Remote enabled and generating service calls, count on getting a call each time it takes a dive.
      If you can be certain you will have 80% or better 100% of the time, they work OK.
      I had a customer about 5 or so years ago that was a genuine jackass, and we were forced to bite the bullet and provide him with a wireless repeater because the MFP kept going offline. The 3 PCs all within a few feet of it worked with no issues.
      Maybe the the newer ones are better, but I really doubt it.
      • Tonerbomb
        AutoMajical Resolutionist
        • Feb 2005
        • 2589
        Mika, I've been using the netgear wireless adapters for 2 or 3 years and all is well................
        Mystic Crystal Revelations
        • Counsel
          • Aug 2011
          • 529
          I had a church once that didnt have internet at all and they would walk across the room and connect a usb and stand there just to print with their laptop to make it easy on them I gave them my old netgear router and set it up by the machine and plugged the machine directly into it so they could be wireless for printing.
          Otherwise i have used netgear LAN adapters or Ext's they work pretty well i even use them at home for my tivo boxes because moca didnt work on the coax i have.
          • copier tech
            • 8195
            I've installed a few Ricoh wifi cards on the Metis series & not had any issues, I extend the 2x wifi antenna as high as possible in a V shape this seems to give the best reception
            • zed255
              How'd ya manage that?
              • 1024
              Never been fond of the Ricoh wireless adapter. It can be flaky and as KenB mentioned the signal has to be rally good for decent performance.
              There are lots of options at the local computer hardware store / big box stores / online that have a better shot at working well and will cost less.
              • sturmtrooper
                Copier Combobulator
                • May 2016
                • 587
                The Ricoh wireless is expensive and the interface for it is stupid and intuitive. A wireless extender or access point with at least one lan port for the copier is a better deal and easier to do, plus it will work with any copier that has network capability.
