mp4001 issue
  • en.
    • Jul 2014
    • 124
    mp4001 issue
    hi all
    i have problem with Ricoh mp4001
    as clear in test
    i replaced development unit with new developer and replaced transfer belt with blade and clean lazer unit
    but problem still
  • Codex
    • May 2008
    • 704
    Re: mp4001 issue
    looks like "flashed" drum....exposed it to light??
    Memento Audere Semper
    • Brianneoe
      • May 2015
      • 322
      Re: mp4001 issue
      If your sample is Long Edge Feed, remove and closely look at your Drum. The Drum is dented. Had a customer do this to me a while back by slamming the right side door close and having the transfer roller unit out of position.
      Good luck
        • 37533
        Re: mp4001 issue
        If it is short edge feed, you might have a scrap of paper or other foreign matter moving around between the laser shield glass and the drum. It could also be something in the laser unit itself.
        • Qball
          • Jun 2013
          • 127
          Re: mp4001 issue
          Good luck
          That's what I was thinking, too.
          Sent from my SM-G900V using Tapatalk
