MP C4503 Received fax but cant send fax with a voip line
  • DanaNL
    • Nov 2016
    • 25
    Hello,
    Today i had to install an Ricoh MP C4503, saddly the custommer had a Voip Line so the FAX is giving me headache.
    i tried already to change the Bitrate of the FAX to 9,6Kbps but no luck also changed it to 2,4kbps but stil no luck.
    i have also shutdown the ECM in the Fax SP.
    any ideas will be appreciatet.
    thanks in advance.
    • 37533
    Re: MP C4503 Received fax but cant send fax with a voip line
    Sound to me like a VOIP line problem, not a machine problem. Contact the VOIP line provider and tell them that the line is not supporting outgoing FAX.
    • DanaNL
      • Nov 2016
      • 25
      The problem is that a Ricoh technician gave me the SP table to change the bitrate but its not function, and when i call Ricoh they simply dont answer because they're on holiday ( netherlands )
        • 37533
        That SP table is only part of the problem. There are certain settings fir the VOIP line itself that have to be made.
        • guitar9199
          • Sep 2016
          • 1100
          See if this helps...Fax SP settings for Digital Phone Systems and VoIP.pdf
          • Gift
            • Mar 2011
            • 2459
            Does it also happen if you use on hook/manual dial (while hering into the speaker). If that works you just need to turn off dial tone detection - that often causes connection issues // set user sw22 bit 0->0 ....IIRC^^. Otherwise the linked PDF includes all neccessary VoIP tweaks and since RX works it seems not a communication problem to me (wich requires a connection).
            • DanaNL
              • Nov 2016
              • 25
              I have already done step 6 and 7 of the FAX SP settings. but stil no results.
              @gift thanks for thinking but the problem stil exist
              • Oze
                Ricoh Fanboy
                • Jul 2008
                • 1663
                Modem Type for RX
                G3 - 1
                Switch 06, Bits 7,6,5,4
                SP1105-007
                Set = 0011
                Max Carrier Allowable Drop Time
                G3 - 1 Switch 0A, Bits 1,0
                SP1105-011
                Set = 10
                Max Allowable frame interval
                G3 - 1 Switch 0A, Bits 4
                SP1105-011
                Set = 1
                • DanaNL
                  • Nov 2016
                  • 25
                  im in awaiting of the customer to check their Portforwarding.
                  • DanaNL
                    • Nov 2016
                    • 25
                    The Ports where forwarded and other machines can fax.....
                    i'm getting a listof wich machines are working and wich not.
                    for now 1 Brother MFC works.
                    so i think its the Ricoh with a faulty setup.
                    i hope they have a ricoh machine there so i can compare the SP table.
                    • Mark Bbb
                      • Jun 2012
                      • 1662
                      many times Brother has a better default setting and standard optional equipment than Ricoh...
                      • Gift
                        • Mar 2011
                        • 2459
                        I noticed the V8 protocol setting is different for the new ricoh mfp (moved to user switches) - (old SP G3 switch still exist but has no effect):
                        User SW 06 → bit #1 +# 2 +# 3 ---> set all to "0"
                        And don't forget User SW22 -> bit #0 -> set to "0"
                        • DanaNL
                          • Nov 2016
                          • 25
                          I have transfered the problem to a Ricoh Engineer, when they finished i will ask them to tell me what the problem was. i will keep you guys informed.
                          • Gift
                            • Mar 2011
                            • 2459
                            Looking forward to know what might does the trick
                            • DanaNL
                              • Nov 2016
                              • 25
                              Problem is solved, the Ricoh Technician did the same as i did the only thing is its right now working........
                              i have checked the steps 3 times and it was al good but did not work. i think he has magic hands....
                              for in the future the solution will be
                              change the baudrate to 9600 in SP 1-105-006 change the value to 0.1.0.0
                              ====================SP 1-106-007 change the value to 0.1.0.0
                              SP 1-104-002 change the value to 0
