Ricoh mp 6000
  • Transam1
    • May 2011
    • 48
    Ricoh mp 6000
    I have an mp 6000 first copy or print out is blurry down 1 side but all following are ok
    this happins when coming out of sleep mode.
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Ricoh mp 6000
    What sort of count do the PM parts have on them? Could be a cleaning problem, sticky blade perhaps.
    Hit it.
    • mikadonovan
      • May 2008
      • 2931
      Re: Ricoh mp 6000
      Depending on the humidity level of the environment, it could be condensation forming on the drum.
      NEVER ASSUME ANYTHING
      • Transam1
        • May 2011
        • 48
        Re: Ricoh mp 6000
        Thanks i will check
        • Mark Bbb
          • Jun 2012
          • 1662
          Re: Ricoh mp 6000
          typical issue with old ricoh's. Cold start, warm start issue...
          There was a RTB for an old model, which I don't remember anymore...
          There was an SP mode that should be changed; I think it was in the manner of which way the fusing lamp get it's power:
          linear or ???
          Firmware upgrade might help.
          You can test to put the machine main switch off in stead of let in go in eco mode, same issue?
            • 37560
            Re: Ricoh mp 6000
            Or charge corona/drum too far past PM cycle.
            • MIKON
              • Jul 2015
              • 188
              Re: Ricoh mp 6000
              Get out your vac
              PCU and Developer Probably needs a good Douching
