Ricoh Aficio MP 4000
  • Vladika
    • Dec 2016
    • 40
    webcam-toy-photo1.jpgwebcam-toy-photo2.jpgHello,
    I have a problem when copying in the ARDF in the portrait, the text at the bottom of the paper, or can not see or be seen half
    • 37533
    Re: Ricoh Aficio MP 4000
    Most likely you have manually selected the paper tray and do not have the original oriented the same direction as the paper in the selected tray. When you nanually select the paper source, auto rotate image is off.
    • Vladika
      • Dec 2016
      • 40
      The same happens to me when I bet that automatically selects the tray
      • TonerMunkeh
        Professional Moron
        • 3865
        One of the original width sensors in the ADF may have failed and it's misdetecting the paper size. Check them in ADF input check.
        Hit it.
        • Elmo
          • Feb 2010
          • 541
          Do you have the problem when copying from the glass
          I Used To Live To Fix Things Now i Fix Things To Live
          • Vladika
            • Dec 2016
            • 40
            Sometimes, but not on every copy
            With the ADF, when I put more paper, and on the landscape copy all ok, but the portrait does not
            • Elmo
              • Feb 2010
              • 541
              Have you done the basics (clean optics,clean lazer glass)
              if you run a test print in sp mode do you get the same fault
              if you use a black pen to write in the area what result do you get
              • Vladika
                • Dec 2016
                • 40
                I cleaned dustproff glass and optics, laser glass did not touch. When you print the list of counters, everything is seen as it has no problem. And when I put the test print page to copy on the glass, missing me at the top and bottom sheet. I've given people on a piece of paper to sign (in blue ballpoint were signed), and that I put in the ADF to copy the portrait, when the copy came out almost nothing has been seen. I asked two pictures at the beginning of the above, perhaps you can see.
                I cleaned the dustproof glass, a copy is then improved, but not completely
                A copy of such copy remains quite good, but when we are certain signatures in the bottom of the paper, that's my problem, because you can not see the whole
                • Elmo
                  • Feb 2010
                  • 541
                  if you use the manual adjust and darken the copy do you get a complete image
                  if printed pages are good the fault is most likely within the optics
                  check all mirrors and lamp are clean
                  check all mirrors are sitting in holders correctly
                  clean the white reference strip on the under side of the glass
                  (on every service visit it is advisable to clean the laser glass)
