Server 2016 scanning
  • mikedci
    • Jul 2010
    • 227
    Does anyone know if this will require a firmware update from the win 10/server 2012 firmware or does 2016 use the same SMB version as 2012?
  • dave w
    • Jun 2015
    • 230
    Re: Server 2016 scanning
    Possibly Network Support Firmware
    • copier tech
      • 8195
      Also depends what model you are referring to?
      The new 04's will be fine as will the 03's unless you have some of the early models on factory FW.
        • 37560
        So far I have not had to update firmware to scan to Server 2016 which is basically Server 2012 R2 with some minor changes. The only problems I have is encountered required have had to do with proper network settings on the MFP. Domain name name must be correct in order for the Domain DNS to recognize the MFP. MFP DNS must be set to local primary and secondary DNS. Computer name and not IP address must be used.
        • mikedci
          • Jul 2010
          • 227
          It was an LW426. The firmware to allow for scanning to server 2012 win 8/10 worked with no other changes needed.
          • rthonpm
            • Aug 2007
            • 2859
            Server 2016 is just the server version of Windows 10 so if you can scan to the latter it will work with the former.
            The run down of server versions to desktop versions that are most commonly seen in the field are:
            Server 2003 = Windows XP
            Server 2003 R2 = Windows XP SP 2
            Server 2008 = Vista
            Server 2008 R2 = Windows 7
            Server 2012 = Windows 8
            Server 2012 R2 = Windows 8.1
            Server 2016 = Windows 10
            • guitar9199
              • Sep 2016
              • 1100
              Make sure to check your NetBIOS settings in the IP v4 protocol. If it's set for "NetBIOS over DHCP", I've seen that cause SMB scans to fail. Setting it to "NetBIOS over TCP/IP" resolves the issue.
              Also be sure the network connection is set to "Private".
              Good luck.
