mpc3003 cover open &no paper
  • en.
    • Jul 2014
    • 124
    hi all
    i have strange problem in this machine
    when i put paper in tray one or tray 2 and the machine load paper i hear sound up and down its look like motor not engage properly then its reading paper and give me ready
    after job is coming the tray read empty paper and full paper and give me cover open in lcd
    i replaced paper feed motor and all vertical transport unit and iob transport and its still the same problem
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: mpc3003 cover open &no paper
    Does it say which cover is open?
    Hit it.
    • HitMan
      • Aug 2015
      • 170
      It's possible you will need to take the paper feed unit out at tray 2. There's a sensor flag that can get knocked out of position. What door is showing open?
      • Counsel
        • Aug 2011
        • 529
        I would hope before replacing all that stuff you checked the flag for the paper end sensor on the feed unit, if a tray is reading empty the flag is probably out of position. If your getting a cover open msg it could be either switch for whichever door is showing open. Faulty door switches can cause irregular problems else ware.
        • en.
          • Jul 2014
          • 124
          the right cover
          and whate the flag ? can you plese show me it by photo
          by the way i replaced
          tray 1 +paper feed motor + paper feed unit (unite ) +iob transport and its same problem
          • nmfaxman
            • 1702
            I would check for a blown fuse on the power supply for 24v that drives the paper lift.
            The same fuse probably powers the door switch.
            I don't know the fuse #, but it should be in the blown fuse indications in the service manual.
            • DougD
              2020 Retired
              • Sep 2016
              • 76
              That ring's a bell from the old FT4527 series.
              Does the machine have a paper bank or any other accessories attached to it?
              • slot
                • Jul 2008
                • 341
                there are 2 boards that control the paper feed/ lift I think on this machine they are at the bottom of the copier at the rear we change one once ony to find out there are 2 iob type boards
                • copier tech
                  • 8138
                  https://www.copierfirmware.co.uk/
                  • LANUN_81
                    • Jan 2017
                    • 12
                    hai guys...i had this problem before.there are the switch back of tray.try to top up some double tape at the back of tray which are attach to the switch in the machine.this issue had bulletin.
