Ricoh MP2000 getting lines on top and bottom of copy.
  • rbazan
    • Dec 2013
    • 70
    [CQ] Ricoh MP2000 getting lines on top and bottom of copy.
    Ricoh MP2000
    RUNNING PRINT METER READING PAGE;
    Feeding paper in LF get line 1/2" from top and a line about 1.5" from bottom
    lead to trail. Using top or bottom cassette; happens before the fuser
    section. If I feed SF paper lines are outside image area (don't see lines).
    Changed Drum, Blade,Developer and Transfer roller. Did not change Charge
    roller-but visually saw no damage to charge roller.
    I cleaned the laser slit glass even though a dirty slit glass would cause
    blank lines, cleaned it just the same.
    I didn't try reducing or enlarging. Any thoughts what could cause these
    lines.
  • qbert69
    • Mar 2013
    • 1152
    Re: Ricoh MP2000 getting lines on top and bottom of copy.
    ....did you clean scanner optics???.....mirrors?
    REACH FOR THE STARS!!!
    Konica Minolta Planetariums!
    • ruben
      The New Guy
      • Oct 2012
      • 1203
      Did you do a forced stop to see if the line is on the drum? If so it will be charge.
      Do the lines go all the way to the edge of the page, if so it is charge / drum, if not it is optics.
      • rbazan
        • Dec 2013
        • 70
        In reply to qbert69 I ran a PRINT METER copy- it doesn't use scanning- only laser optics. NOTE: The lines were there before I changed the Drum and Developer.
        In reply to ruben I stopped copy before fuser and lines happen before. I replaced most of the major drum parts except the Charge Roller because I didn't have one and because it didn't have any visible damage. The lines didn't match anything in paper path area that I could see.
        I'm going to order and change the charge roller and install it on next call- I'll also try reduction and enlargement just to see if there is a difference.
        I don't want to remove and clean laser ass'y but it might be my last resort.
        If you can think of any test or solutions; they are appreciated. Thanks!
        • davel
          • Oct 2011
          • 1095
          It won't be laser, change charge roller and its cleaning roller, check for bad blade.
            • 37373
            Clean the charge roller with a soft clothe moistened with water.
            • qbert69
              • Mar 2013
              • 1152
              If this is a Black & White machine, the rubber charge rollers last a looong time!....I just usually use a paper tower moistened with water and a steady scrub...usually takes care of it!....I can do the same for the rubber charge rollers on Kyocera machines too! If the drum looks good and the developer is good, the only thing to change would be the drum cleaning blade!!!
                • 37373
                If you read the first post, everything except the charge roller WAS replaced.
                • geardriven
                  • May 2008
                  • 32
                  Hi
                  Just my 2 cents does the lines appear if you run it through the ADF the same as off the glass I have seen a speck on the optics cause similar problem
                  • andy227
                    • Jan 2013
                    • 219
                    This may sound silly or obvious, but when you changed the drum and blade did you vac out the cleaning section ? Try another charge roller, even if its another used one.
