White stripes in all colors on the 751 pro
  • ronen
    • Jun 2015
    • 1
    lines.jpgWe have these white stripes showing up an all colors the Tec’s replaced almost everything and after 100 prints +- they come back and we can’t find the cause of the problem anybody has any idea?
    Thanks for your help
  • freginold
    • Sep 2010
    • 102
    Re: White stripes in all colors on the 751 pro
    Did you replace the entire DV units or just the developer? I've seen this happen where the doctor blade gets loose on one side, causing striping. Check that the gap is equal on op and non-op sides, and within spec.
    Could also be something in the toner system, dirt or something, getting sucked into the DV units and lodging against the doctor blades.
    Config page instructions for copiers, printers, & fax machines
    • davel
      • Oct 2011
      • 1104
      Not trained on Pro machines but are the white lines in the same spot on all colours, if so it's not PCDU related, if not look at laser glass and dev unit.
      • DougD
        2020 Retired
        • Sep 2016
        • 76
        Not trained on this machine but there is more going on here than the blank lines.
        I would call them "fish scales".
        If I didn't know better, I would blame ozone buildup.
        Check for blocked air filters and proper room ventilation.
