Ricoh drum conversion between color 01 series & 02 series
  • copywhisperer
    • 8
    I would like to ask you guys about drum coversion specifically Ricoh color 01 series & 02 series.
    First of all, it's about K drum. D0892250 is for MPC 01 series & D1442251 is for MPC 02 series & then I have a question. Can I use D0892250 (MPC 01 series K drum) into MPC 02 series K drum instead of D1442251? It now is C$100.00 price different & I am hoping that I can use D0892250 for MPC 02 series K drum to save cost & my car stock volume.
    Secondary, it now is about color drums. I have been using D0292256 K drums to replace both 01 & 02 color drums by carrying out several modifications for a long time & then now I have another question. Can I use B2242042 K drum instead of D0292256 when I have to replace 01 & 02 color drums. I am sure that there are some necessary modifications such as swapping pins & filing plugs even if this is possible but let me know if some of you guys have already explored these things & if it's successful.
    Thank you for your prompt reply
  • copier tech
    • 8237
    Re: Ricoh drum conversion between color 01 series & 02 series
    We basically only use D0292256 for both colour & Black on all the MPC3001 - MPC4500 - MPC3002 Series
    There is as you say I few modifications to carry out with this is very simple & worth it for the cost saving.
    See attached pdf.
    • copier tech
      • 8237
      Ricoh Drum Mod Sheet.pdf
      • Oze
        Ricoh Fanboy
        • Jul 2008
        • 1663
        See attached pdf.
        We use B2242042 as the only mod to the black drum to be used for colour is to shave the connector.
        • Imprestik
          • Aug 2012
          • 297
          Even easier and cheaper is to use the maintenance kits from the SPC820 and SPC830
          They work a treat with little modification
          • Oze
            Ricoh Fanboy
            • Jul 2008
            • 1663
            That mod sheet I posted up mentions both those kits AND how to mod them
