MPC6502 sc670 and sc819
  • fireater
    Repair God? not quite
    • Apr 2006
    • 253
    I have a copier throwing sc672-11 and sc819's. On ricoh's suggestion i replaced the 900 dollar controller board and was told to cut all cable ties to Op panel and reseat all connectors from op panel to IOB AND all other IOB connectors. UPDATED Firmware. 2 weeks later Now I get SC670's and SC819's. Any Thoughts?
    EDIT customer called ..672-11 just reoccurred..
    I fix copiers ...Well Sorta
  • LANUN_81
    • Jan 2017
    • 12
    Re: MPC6502 sc670 and sc819
    SC819 will occur when the customer direct print from website.suggest cust to download first then print or update the firmware.
    • gkalman2004
      • 157
      For 819 ask from the user if the error ocur when print pdf documents in booklet mode in this case you need to install also the patch(es),
      for the 672-11 just reupdate the firmware powersaving sys with newer version
      • fireater
        • Apr 2006
        • 253
        I did all firmware when I replaced the controller.....but I will check versions.
        Also it will error out sometimes when you turn it on. The screen hangs for about 3 to 5 minutes then drops to the sc670
        • gkalman2004
          • 157
          For 670 if you have mailbox you must update the firmware also (mailbox-ontario-d)
          search in the attachement for 670 you will find it
          ScCumulated.pdf
          • oyedokunmj
            • Sep 2016
            • 7
            How to change language of HP color LaserJet cm 6030mfp to English language
            Sent from my Infinix X510 using Tapatalk
            • Iowatech
              Not a service manager
              • 3930
              For HP questions, ask here:
              http://www.copytechnet.com/forums/hp/
                • 37556
                I think he is trying to get more red cards.
                • fireater
                  • Apr 2006
                  • 253
                  so replaced op panel and usb cable again recommended by Ricoh tech support. turned on machine and waited ... 4 minutes later SC670-00. does Ricoh have a dart board repair method when you call them for help? I can guess at shit too!
                  I'm gonna do nvram and system memory next.
                    • 37556
                    No. They have a database look up for when you first call in. They should have given you a case/reference number. When the quick fixes don't work and you call back in on the same case number, you will either get a product specialist or if you get another help desk tech who will seek the assistance of a product specialist. If you keep having the same problem you will either eventually the product leader or you can fill out an escalation request and Ricoh will schedule a regional rep visit.
                    • fireater
                      • Apr 2006
                      • 253
                      Update.. now i have put in new nvram, hdd's, and memory
                      worked for a week and back to screwing up
                      powersupply?
                      • sturmtrooper
                        Copier Combobulator
                        • May 2016
                        • 587
                        I dunno. Sometimes the dartboard method seems pretty apt. Last problem we had was a MP401 where the OP panel buttons were all wacky. Push the start button and it goes to sleep. Called the hotline and suggestion I got was replacing the OP panel. Which is a $525 part. We replaced the two PCBs that the buttons are on for a total of less than $100. Problem solved.
                        • semi
                          • Sep 2008
                          • 195
                          If your getting SC670-OO,try disconnecting the flat ribbon cable & power connector on the PFB PCB ,you should get SC 665-03 straight away,machine boots.The PFB PCB is fried,I alsohad 3 damaged tandam tray sensors which caused my 670.Worth a shot!
                          • MitchD
                            • Oct 2012
                            • 164
                            http://www.copytechnet.com/forums/ri...ighlight=SC670
                            Here was my experience with a SC670 on the MPC6502
                            Hope it helps
                            "Heavy music to the normal ear is nothing but a loud annoyance. Most people think of it as obnoxious, talentless music but to someone who really listens and is really in love with music knows how beautiful and amazing it can be" Tommy Rogers of Between The Buried and Me"
                            • fireater
                              • Apr 2006
                              • 253
                              Hope it helps
                              was this pinch in the wiring on the fuser or at the back where the fuser plugs in to the copier
