spc830 - ITB parts number for only the belt
  • Mark Bbb
    • Jun 2012
    • 1662
    There seems to be no parts number for belt only.
    Has anyone tried to put an itb belt from a mpc3002 (or so???).
    Thank you for your answer.
  • copier tech
    • 8144
    Re: spc830 - ITB parts number for only the belt
    The "SPC" printer machine versions are designed to have consumable replicable parts, e.g complete fuser & ITB not belt only & fuser sleeve.
    However yes the 3002 belt is identical so simply replace that, however the spc units are quite cheap so you may find the 3002 belt only costs nearly the same!
    On another note you can fit the complete fuser & ITB unit from the SPC830 into the mpc3002 (with a simple mod) again because they are cheaper than replacing the individual parts.
    • markgoscinski
      the part number for the compatable belt only is B22361630,this will sort your problem
      • Mark Bbb
        • Jun 2012
        • 1662
        No match on that number. There is 1 digit to much...
        • markgoscinski
          Sorry typo B2236130 Apologies.
          • Mark Bbb
            • Jun 2012
            • 1662
            Thank you. That number is the belt for mpc2500. Do you also use this belt in a mpc3002?
