MPC 8002 toner powder everywhere..
  • gkalman2004
    • 157
    Hi
    I have a "new" MPC8002 Machine with 75k printed pages, i clean the whole machine every 2 month because tonner powder spots etc..
    I know this type have lot of problems but i dont find any idea why the machine loose so much powder in relative short period.
    In the service manual the preventive maintance is around 300 K but i already have the itb full of powder the transfer and also the fusing.
    I don't have problem with the machine except the monthly cleaning, so any idea are welcome if help me to bring a longer time extension...
    Any advice?
  • LNorris
    • Sep 2008
    • 645
    Re: MPC 8002 toner powder everywhere..
    c8002.pdf
    there is a tech bulletin on this
    • gkalman2004
      • 157
      Originally posted by LNorris
      [ATTACH]35647[/ATTACH]
      Yes it will help me to make the new settings.
      I already updated all the firmware but the settings matter
      After i search again i find this info also in the cumulated sc file (i missed this one ..thanks for the heads-up)
      Thank you very much
      • gkalman2004
        • 157
        Thank you very much
        I checked today the machine but i already have the firmware upgrade and sp SP3301-023 was already set to 0.05 so not helped this tech buletin.
        I have the same situation
        • gkalman2004
          • 157
          Hi everybody.
          I found my problem source
          I loose toner on the sides of developer unit, it fill the side of the itb with powder and all the machine.
          [Front] p/n: D1363412 (SEAL DEVELOPMENT ROLLER:FRONT UPPER)
          [Rear] p/n: D1363413 (SEAL DEVELOPMENT ROLLER: REAR UPPER)
          I find the rtb with the procedure but only in the pro c5100 model i find it Document ID : RD137146 Troubleshooting Bk toner scattering from the dev unit side seals
          I will do it also for the CYM developer unit the same procedures
          I need to do this correction
          Thank's
          • Timmytronic
            • Oct 2010
            • 249
            Change the devs. Sounds like they have not been set up properly. I have had this a few times in new machines. Got the Devs and wait 10mims before you initialise. This will make sure you have no static or electric in the Dev that can cause failed set up results and this.
            Hope me that helps.
            Tim.
            • gkalman2004
              • 157
              Thank you for this delayed answer, i already fixed my machine but...
              Interesting you try to tell me something like every time when i buy a new machine i must change the developer because it is not setup properly??
              Or reading the service manual you can find how to reconfigure the right developer density for the development unit so i just followed the procedure.
              • Timmytronic
                • Oct 2010
                • 249
                Hiya. I was not saying you had not set it up wrong, I have had new machines but already had been set up from the factory and I don't think they do it to the book.
                What did you do? Was it the devs?
                Tim.
                • gkalman2004
                  • 157
                  I read the rtb with the tonner scattering and there was a setting
                  i set 3301-023 M/A LowErr:K from 0.10 to 0.05
                  the values is ([0.000 to 1.000 / 0.100 /0.001mg/cm2/step]
                  first it not fix my problem and is not writen in the rtb ..
                  but one step down i find also the 024
                  3301-24 M/A LowErr:Col i set also to 0.05
                  the values is [0.000 to 1.000 / 0.200 /0.001mg/cm2/step]
                  so a little bit bigger but i don't care i set this also to 0.05
                  Also i put the new seals with succes on the developer unit
                  Until now the machine working well (maybe until the seals come off (i cross my finger))
