Ricoh Pro 751 ,white spot on all colors
  • pinspin
    • Oct 2011
    • 156
    Hello ! We have Ricoh Pro 751. The problem - random white spots on all colors , more on black .This spots we can see on transfer belt too and not on the PCUs . Also it was SC 411 , but we cleaned VD sensor and code gone , if the important . Thanks for any advices .
  • davel
    • Oct 2011
    • 1104
    Re: Ricoh Pro 751 ,white spot on all colors
    If spots are the same on all colours replace transfer belt
      • 37491
      I had a Pro 8110s with the same type pattern of spots. It was caused by the ITB transfer roller.
      • pinspin
        • Oct 2011
        • 156
        Thanks ,friends ! I changed transfer belt and 4 ITB transfer rollers . It helped . Thanks again )))
        • Rorschach
          • Nov 2008
          • 64
          In addition to the belt and 4 image transfer (D0746158) rollers that you've already changed, I would suggest the opposed roller (D0746110) as well. This is the ITB bias roller at the very bottom of the ITB assembly that is directly opposite the PTR. All five rollers are on an 1800K PM cycle.
          Today's subliminal quote is:
          • pinspin
            • Oct 2011
            • 156
            Thanks ,my friend !
            • markgoscinski
              Please replace the 4 transfer rollers underneath the I.T.B. belt.Had this before and the sponge Bias Oppose roller replace aswell on the I.T.B. unit
              • pinspin
                • Oct 2011
                • 156
                Thanks !!!)))
