MP2001 light image . .
  • GeorgeBest
    • Jul 2009
    • 526
    Hi,
    Have only one MP2001 in the field.
    Customer called for a dark image and some lines. (95K)
    So, I did maintenance, changed the PCU,developer, charge rol and cleaning blade. (all from the MP2000 model)
    Did SP2801, now the image not good, to light and not equal on full page, the top is lighter then the bottom...
    Anyone? Is it the right PCU, developer ?
    thanks in advance
  • Hoosierdaddy
    • Oct 2016
    • 182
    Re: MP2001 light image . .
    Originally posted by GeorgeBest
    Hi,
    thanks in advance
    It Takes a different DV #D1589640 and CL Blade #AD042083 according to Product Support Guide. Blade is probably the same as the MP 2000 Series but DV is Unique. Hope that Helps.
    • sandmanmac
      • 3981
      Seems to me, that these would have been good questions to know answer to beforehand....and also easy to find
      • NeoMatrix
        Senior Tech.
        • 3513
        Given the machine was previously giving dirty over toned copies,
        the current problem sound's like an issue with dirty optics.
        o Check the charge roller is in the correct home postion.
        o Developer gears turning the toner distibution auger ?
        • nadimtopsecret
          Experienced Tech
          • Mar 2013
          • 47
          Did you services the LASER unit ?
          Asking although this is a primary issue !
