is there anything better in a mpc3502 vs earlier series?
  • fshead
    • 2376
    gd morning.
    i have a pending sale with the midrange lease returns ricoh 30 to 45 cpm color machines.
    i sold a bunch of mpc2800,3300,3001 and 3501s but low meter return units are dried up.
    so i am looking the 02 series but dont know if its equal or better or worse.
    for running 85% black only how does it hold up.
    thnx in advance
  • Zeldaman
    • Mar 2011
    • 946
    • fshead
      • 2376
      Re: is there anything better in a mpc3502 vs earlier series?
      thnx
      what would you say black copies max monthly volume,if the machine less than 100k i can assume the sleeve roller is original
      or was this a modification in field?
      i use to sell only finch paper but stopped selling paper many years ago..
      is hammermill or staples bond any good?
      appreciate your insight..
      • Zeldaman
        • Mar 2011
        • 946
        • fshead
          • 2376
          thanks
          • Athlontini
            • Jun 2012
            • 269
            Originally posted by Zeldaman
            Hi there!
            Remove metal-pins for colour-drums, so you can use the black B224...drum.
            Can you explain more about this? I never heard of any mods for color drums on the 02 series.
            • copier tech
              • 8144
              Have a read, this doc may explain better.
              Basically you can use the cheaper D0292256 for all for drums (with a simple modification to machine & the PCU)
              Ricoh Drum Mod Sheet.pdf
              • tufbnme
                • 493
                [ATTACH]35756[/ATTACH]
                Use the B2242042 drum, much cheaper and perform well.
                • Athlontini
                  • Jun 2012
                  • 269
                  Very nice. The last version of this cheat sheet that I saw (about 4 years ago) didn't have those additional pictures showing the mods for the 02 drums. Thanks!
