D422
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5013
    D422
    Hi
    User have Nashuatec D422 with toner problem.Won't recognize original toner.Masage install toner wont go away?!
    Is this some kind of classic issue or maybe toner problem? Thanks in advance!!
    Canon tech
  • sandmanmac
    • 3981
    Re: D422
    Often the 'plug' from the top of the previous toner bottle gets stuck and remains in the mouth of the toner hopper, blocking the toner flow
      • 37491
      Re: D422
      Check that the gears on the development unit are not stripped. This is a common problem with PCU that have been rebuilt. When they get stripped, the mixer shafts do not turn and new toner is not mixed in.
      • zoraldinho
        • Mar 2008
        • 5013
        Re: D422
        Nailed!
        Developer won't suck. Can you please confirm part number for drum/developer unit.Thanks!!
        Nashuatec LR022 PCU Drum/Developer Unit EDP 4800057
