problem with fax aficio 350
  • red flower
    • 28
    I have copier aficio 350 when i working it as fax it send faxes but not receive any faxes .I want to know how can i solve this problem??
  • E Winter
    are you shure you are a technician?
    Try to encircle the problem:
    - is the line chord inserted into the correct plug?
    - what happen if you call that fax with a phone - does it pick up your call?
    - have you checked the current rx mode?
    pretty common stuff dude
    • red flower
      • 28
      - Yes line cord inserted correct
      - when call it with phone i hear the ring and don't open as fax Although the communication indicator lit after no. of ring and hearing beep of receive on fax ONLY
      - YES and adjust it at auto reception mode
      • TonerMunkeh
        Professional Moron
        • 3865
        I'd be looking at the fax cable, is it one that you've pinched off another machine? If so, it won't work.
        Hit it.
        • E Winter
          Dunno if I got this right: Did the machine "telling" you the handshake sounds in the phone?
          In this case it should be possible to establish a fax transfer. Maybe there's a stupid setting like authorized RX enabled. Have you tried to do a complete parameter/factory reset of the fax option?
