- is the line chord inserted into the correct plug?
- what happen if you call that fax with a phone - does it pick up your call?
- have you checked the current rx mode?
pretty common stuff dude
- Yes line cord inserted correct
- when call it with phone i hear the ring and don't open as fax Although the communication indicator lit after no. of ring and hearing beep of receive on fax ONLY
- YES and adjust it at auto reception mode
Dunno if I got this right: Did the machine "telling" you the handshake sounds in the phone?
In this case it should be possible to establish a fax transfer. Maybe there's a stupid setting like authorized RX enabled. Have you tried to do a complete parameter/factory reset of the fax option?
