MP4002
  • katash
    • May 2010
    • 221
    [Misc] MP4002
    Guys,
    hope you are well, what do i require to convert an MP5002 to an mp4002 or vice versa as the Controllers are different
  • davel
    • Oct 2011
    • 1108
    Re: MP4002
    Buy the machine that you need.
    • freginold
      • Sep 2010
      • 102
      Re: MP4002
      Aside from all the stickers and decals, probably several boards. Look through the parts manual and see which boards have dual part numbers (i.e. a part number for the 4002 board and a different number for the 5002 board).
      Config page instructions for copiers, printers, & fax machines
      • sturmtrooper
        Copier Combobulator
        • May 2016
        • 587
        Re: MP4002
        Originally posted by katash
        Guys,
        If I were to attempt this crazy venture my GUESS would be to replace the controller. the controller NVRAM, and the EEPROM on the BCU.
        Doing this would lose you your counter, all your non default settings (so hopefully you backed them up to an SD card AND printed a non default report) and there is no guarentee that it will work.
        The only reason I can see to want to do this is to buy a cheap 4002 and try to resell it as a 5002, shady business to say the least.
        • katash
          • May 2010
          • 221
          Re: MP4002
          Guys,
          no shady deals just had an mp4002 that the controller is dead and i had an mp5002 controller just thought it could work,thanks for your input
            • 37560
            Re: MP4002
            Guys,
            You will get an SC 995-004, incorrect model controller installed, and will be unable to operate the machine.
