help ????
  • ahmed_dcc
    • Sep 2012
    • 36
    help ????
    Hello everyone
    want to help the code errors
    Richo machine MPC 300 SC 995-001
  • gkalman2004
    • 157
    Re: help ????
    From the manual
    When installing the new BCU
    1. Remove the EEPROM from the old BCU.
    2. Install the EEPROM on the new BCU after you replace the BCU.
    3. Reassemble the machine.
    4. Turn on the main power of the machine.
    5. "SC995-01" occurs.
    6. Enter the serial number with SP5811-004.
    7. Turn the main power of the machine off and on.
    So check the BCU controler board
    • Defective BCU
    • EEPROM Replacement error
    1. Install the previous EEPROM.
    2. Input the serial number with SP5811-004, and turn the main power switch off/
    on.
    • samadshafi
      • Mar 2017
      • 16
      Re: help ????
      Originally posted by ahmed_dcc
      Hello everyone
      • ahmed_dcc
        • Sep 2012
        • 36
        Re: help ????
        Thanks for the help, but useless than you did the same and all the mis code already exists .
        If the problem in the firmware of renovation work, how do I have and where I can get a new version of firmware
        Thank you again
        • gkalman2004
          • 157
          Re: help ????
          Thank you again
          • ahmed_dcc
            • Sep 2012
            • 36
            Re: help ????
            I've done all the instructions, but there is no change
              • 37532
              • samadshafi
                • Mar 2017
                • 16
                Re: help ????
                hi can you send me the exact model the machine i have all firmware for all richo machine
                • ahmed_dcc
                  • Sep 2012
                  • 36
                  Re: help ????
                  thanks for the help
                  But excuse me sir How do I get this the exact model the machine .
                  • ahmed_dcc
                    • Sep 2012
                    • 36
                    Re: help ????
                    Originally posted by terramobil
                    Does the machine accept the new serial-number? As far as I know, you have to use special service mode (143) to change the serial-number.
                    thanks for the help
                    But what this code is (143) and how it in to him
                    • francisco
                      • Nov 2009
                      • 168
                      Re: help ????
                      [QUOTE=ahmed_dcc;554398]Hello everyone
                      Hy
                      did you change any board?
                      did you change nvram?
                      what happened.
                      • ahmed_dcc
                        • Sep 2012
                        • 36
                        Re: help ????
                        [QUOTE=francisco;554500]
                        Hello everyone
                        Hy
                        what happened.
                        Thank you
                        I've Change (Nvram)
                        • ahmed_dcc
                          • Sep 2012
                          • 36
                          Re: help ????
                          Hello everyone
                          Hy
                          what happened.
                          1. In the beginning you change the entire main board then the problem occurred and the code 995-001 then you returned everything as it was in the first
                          2-then you change Nvram and put new serial code did not disappear and still the problem as it is
                          • francisco
                            • Nov 2009
                            • 168
                            Re: help ????
                            [QUOTE=ahmed_dcc;554504]
                            the serial number is in eeprom (bicu board)
                            when you put a new nvram in the controler board,SC 995 will appear, you must turn off the machine(the serial number is automatic copy from eeprom to nvram)
                            when you turn on again the machine is ready.
                            the nvram must be a new one ,not one that was in another machine before
                              Re: help ????
                              thanks for the help
                              it sounds like
                              1) you don't have the service manual
                              2) you are not a dealer tech
                              3) you haven't called Ricoh
