Will a mpc3501 hdd work in a mpc3502?
  • fshead
    • 2363
    greetings.
    I just purchased my 1st 02 series ricoh colors and have an sc 860/870 and formatting the HDD
    failed which I am assuming the customer pulled the HDD.
    I havent opened the controller yet but figured I d ask here.
    thanks
    • 37379
    Re: Will a mpc3501 hdd work in a mpc3502?
    If the machine boots but just displays the SC at the bottom of the screen, enter System SP mode and print the diagnostic page, SP-5990-005. It should show if there is a HDD.
    • sandmanmac
      • 3979
      There's nothing special about Ricoh HDD's. Any off-the-shelf HDD will work -so long as it's AT LEAST the size of the original. Larger caocity is OK
      • fshead
        • 2363
        thanks.
        i never run these machines till i pull all the units out and inspect for any screws,paper clips or staples
        that might wipe out a drum or ITB..I learned that the hard way way back.
        I pulled the back and no HDD but they did leave the 2 connectors so I am happy.
        Just found a 250 gig drive on my shelf and will try that..I think the mpc3501 used a 320gig but dont know the 02s as
        no manual yet here
        • mikedci
          • Jul 2010
          • 227
          When they first came out they had 250 GB HDD's so your 250 GB should be fine. Ricoh did update the part's manual to 320 GB drives.
          201504-01 1504 Modification - D1425765 HDD:TOSHIBA:25O/O Model At-C3: M4445201 HDD:320GB:AQUARIUS
          • fshead
            • 2363
            THNX
            I opened up my other 3502 and see its a 250gig sata laptop drive..
            Toshiba 250GB Internal 5400RPM 2.5" (MK2575GSX)
            • fshead
              • 2363
              I ended up swapping out a hard drive from my mpc 3002 and machine came up
              with a message showing HDD swapped out and the a SC 876-05
              "Installed NVRAM or HDD which is used in another machine"..
              1. Reinstall the previous NVRAM or HDD.
              2. Initialize the HDD with SP5832-004.
              after option 2 it seems fine.
              • fshead
                • 2363
                i just installed a used but tested 250 gig seagate sat laptop drive in mpc3002.
                upon start up machine knew and asked me to format it on screen and then reboot/restart and DONE..easy
