Main charge cleaning MPC4504
  • Mr2crazed
    • Jun 2014
    • 35
    This may be a rather stupid question but how to you get to the main charge roller to clean it? I have a a machine that has a line in grayscale from a dirty main charge roller. The service manual doesn't document how to remove the main charge.
  • davel
    • Oct 2011
    • 1104
    Re: Main charge cleaning MPC4504
    No details in manual because you are expected to replace entire PCU unit, but its probably similar to previous models.
    • copier tech
      • 8144
      Same as any other Ricoh, split the drum & dev units then you can see the charge roller.
      If however you're getting white lines try cleaning the laser glass & also check the dev roller for a visible deletion.
      • HDSB
        Field Tech
        • Feb 2013
        • 64
        if its the same as the 03 models, turn it on its side and theres two screws on the underside to remove the charge roller assy.
