Lanier 5580 Power Code issue
  • techd
    • 32
    Hi i got a older copier, i have never really been around a lot of Lanier copiers, anyway the power code looks like the ones that come with dryer the 3 prongs look like they are 220v, what kind of adapter of outlet do i need in order to operate this?, any suggestions are welcome.
  • cobiray
    Passing Duplication Xpert
    • Mar 2008
    • 1199
    I'm not familiar with that model, but the operators manual states the line should be a 20 amp circuit. If you could take a picture of it we could confirm the type for you.
    • techd
      • 32
      here is the picture.
      • nmfaxman
        • 1702
        It is a 110v 20 amp dedicated plug.
        Go to a hardware store and get the female end of the 20 amp and male end of 15 amp plug.
        Solder a thick gauge wire to each end and you have what we used to call a pig tail.
        As long as machine doesn't pop breakers it will be OK.
        • rthonpm
          • Aug 2007
          • 2859
          For this non-Ricoh Lanier machine, the power specs are: 115v 20 amp, 50/60 Hz.
          • techd
            • 32
            ok thanks i went to the hardware store and the guy showed me the wall plug that i need, and i think i might need to get a breaker for it, thanks!
