Wireless and bluetooth printing (mp c2504sp)
  • sharpmind
    • Sep 2009
    • 478
    Guys, can you give me some inputs or better I say, can you give me some instruction material on how to configure wireless/bluetooth printing in MPC 2504SP. The machine is already connected in LAN and it is working. The user asks me how to print with his smartphone using wireless or bluetooth. I go to SCREEN FEATURES and I enable the WIFI/BLUETOOH function. nThe machine is then connected to WIFI/BLUETOOTH. I tried to search the printer with the smartphone but unable to find it. If I have my own smartphone with the HOTSPOT enabled, can I print in the machine even it is connected to the client's network? The machine is in USER CODE AUTHENTICATION.
  • Zeldaman
    • Mar 2011
    • 946
    • nadimtopsecret
      Experienced Tech
      • Mar 2013
      • 47
      Re: Wireless and bluetooth printing (mp c2504sp)
      Please download "Smart Device Connector" from Google play store.
      Here I also giving you some link which may help you to configure you easily.
        • 37513
        If the mobile device already has access wifi access to the network that the C2504 is connected to, then you have to download and install Ricoh Print&Scan app from either the app store or google play.
        • Juggy
          Technical Support
          • Sep 2007
          • 101
          Hi in screen device setting you need to change the interface setting from machine network to WiFi if you want WiFi hot spot printing. Then configure WiFi direct setting join the hotspot and bingo you will be able to print using mobile print scan app or smart device connector app.
          Sent from my Lenovo K33a42 using Tapatalk
          • mikadonovan
            • May 2008
            • 2931
            I got disgusted using Ricoh's print app, as it only works sometimes. On the occasion that I have to print from my phone, I've been using Hammermill's print app (get it from Google Play Store). It has yet to fail me.
            NEVER ASSUME ANYTHING
            • hdmr
              Helpdesk Engineer
              • Feb 2013
              • 51
              Has anyone managed to get to the bottom of the WiFi Direct printing or Bluetooth printing?
              Also can you have WiFi direct and LAN printing or is it one or the other?
              Will LAN printing work with Bluetooth?
                • 37513
                Bluetooth printing with the SOP is extremely short range even for Bluetooth. You almost have to have your mobile device setting on the SOP plus you have to have registered your device with the SOP. WiFi direct is also short range, near vicinity of the SOP. It is a very low power WiFi transmitter in the SOP itself. LAN is just that, your local area network. To use it with a mobile device, you need to be connected to the LAN WiFi, if it has one.
                • rsyarcia
                  Hair Straightener Tech
                  • 711
                  just enable the bluetooth from the machine and your phone.Then search the device from your phone. That's it.
                  Nobody is perfect..
