AF32224C Dev Unit Streaks
  • Voltage
    • Jul 2008
    • 282
    Hi Guys
    Any ideas of how to get rid of the white lines on the AF3224c dev units?
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    You can try turning the dev roller backwards but most the time you will need to replace the unit.
    • Voltage
      • Jul 2008
      • 282
      I opened it up and cleaned the docter blade and it works fine. Only problem is all the seals got damaged when in removed them. So no luck.
