Ricon Aficio 1515 problem
  • Orion2010
    • Jun 2015
    • 176
    Hello to everyone,
    I have a problem with my Aficio 1515. The scanner it's stuck in the middle and doesn't moved anymore. I have turn off and turn on but again the same thing.
    Do you have any idea what can i do?
  • davel
    • Oct 2011
    • 1097
    Re: Ricon Aficio 1515 problem
    Pull it apart and find what is stopping it.
    • Orion2010
      • Jun 2015
      • 176
      Originally posted by terramobil
      It is a bit poor when a qualified technician only comes up with the idea of turning the device off and on to fix a problem.
      Terramobile, I never work with ricoh aficio we are not here to make witty, if you know something for this problem say it, if no do not write
      • keithxxiii
        Just a tech
        • Nov 2014
        • 468
        Have you checked the scanner rails if there is obstruction?
        How about the strings? the scanner drive motor? The board that powers the scanner motor? The board that energizes the motor?
        Aye! Cut the crap
          Originally posted by Orion2010
          Hello to everyone,
          a senior tech even tho haven't worked on these machine should be able to do more than off/on. I surprised you didn't pop the glass and look inside. Or maybe I'm just a little more inquisitive than most.
          • HitMan
            • Aug 2015
            • 170
            It's possible the original scanner pins have not been correctly removed. If you look under the scanner there may be black plastic tabs sticking out. Twist and pull down to remove hope this helps
            • keithxxiii
              Just a tech
              • Nov 2014
              • 468
              And an SC Code will be logged
              Aye! Cut the crap
              • Polarbear
                • Feb 2012
                • 1070
                Hello to everyone,
                Please supply a little more information:
                Are there noises when you turn the machine on? Can you hear the scanner motor come on?
                Are there any SC codes or other messages displayed on the screen?
                Does the scanner lamp come on?
                Does the machine have a DF on or just a platen cover?
                Have you done an output check on the scanner motor to test if it works?
                In order for us to help you, you need to supply as much info as possible, as we are not at the machine to be able to assist you.
                Press the GREEN button!!
                • Chicko
                  • Sep 2015
                  • 36
                  Try this , open the platen glass and move scanner to home position. Then switch on. If the scanner moves again to the same position and stops then there's a possibility its a problem with the scanner drive motor
                  • service_man
                    • Jul 2012
                    • 59
                    But do not withdraw from the pulleys, it does not lose synchronization
