MPC4503 fax issue
  • barber782
    • Aug 2011
    • 286
    MPC4503 fax issue
    Hi everyone,
    I've got a customer with a MPC4503 where it doesn't print any receiving faxes. Sends faxes fine.
    Machine will say it's receiving a fax but then fails to print. Looking at the rx file status it's shows the job has been completed.
    Iv already updated firmware, checked fax settings such as auto print and memory lock.
    Any suggestions would be appreciated.
    Cheers
    Sent from my GT-I9195 using Tapatalk
  • keithxxiii
    Just a tech
    • Nov 2014
    • 471
    Re: MPC4503 fax issue
    make sure that fax forwarding is off and print is on. You can also print the parameter settings list and check whatever dubious stuff is turned on/off.
    my last option is to reinitialize the sram then pray.
    Aye! Cut the crap
    • barber782
      • Aug 2011
      • 286
      Lol looks like I'm gonna have to start praying then.
      • keithxxiii
        Just a tech
        • Nov 2014
        • 471
        I found this thread below
        MP 4001 Inbound Faxes STUCK? Try this trick!!
        it might help you
        Aye! Cut the crap
        • barber782
          • Aug 2011
          • 286
          Can't see the link. Can you send again please.
          • keithxxiii
            Just a tech
            • Nov 2014
            • 471
            http://www.copytechnet.com/forums/ri...try-trick.html
            Aye! Cut the crap
            • anothertech
              • 1771
              I am having this same problem with a new install of a MPC6004, updated all firmware and java, cleared fax application and sram, replaced fax board, no luck.
              Ordered controller. Any other Ideas?
              Fax forwarding is not on, it is set to print the faxes. Will not print a fax confirmation either.
              • keithxxiii
                Just a tech
                • Nov 2014
                • 471
                The jumper positioning of 04 series is different from other models. Make sure the jumper is properly positioned as per the manual
                Aye! Cut the crap
