SC672-12.. MPC4503..intermitant
  • spaceman99
    • Jul 2009
    • 174
    [Error Code] SC672-12.. MPC4503..intermitant
    Hello
    Have got a MPC4503.
    1st call.... Dead mch reported and smell
    2nd call.. eng fitted PSU, however, no SP mode or other functions. then fitted Controller.. Got copy screen and function , BUT ..no Sp mode. Then changed HDD . Now got Sp mode and machine working. however, 672-12 appears after 20mins, Put old controller on SC672-12 appears immediately. Placed new controller back on . he could not work out why it went dead ?
    3rd Call... I arrived, have updated all firmware and power save mode. turned of pwr save mode. replaced controller. after 20 /40/50 minuets SC672-12 appears. Followed the RTB by Ricoh and this did not work....On/Off reset and it keeps happening.
    ordered BICU , Image control PCB and NVRAM.and another PSU. Ready for next visit.
    has anyone else had this. your feedback is welcome..
    Thank you in advance.
  • Lunatech
    • Oct 2012
    • 208
    Re: SC672-12.. MPC4503..intermitant
    The service manual also indicates that the operation panel connector and or harness could be at fault. I would imagine the panel itself could be at fault even though the manual does not say so. FWIW. Good hunting.
    • ruben
      The New Guy
      • Oct 2012
      • 1203
      Had a few of these, most we sent back as DOA, others we tried control panel, cables, firmware, and boards. All with mixed results.
      Seems to be hit and miss.
      • gkalman2004
        • 157
        Usualy the operation panel connector loose, broken, or defective
        The users move up down too often the operation panel and the cable has failed.
        • MitchD
          • Oct 2012
          • 164
          The few times I have run into this it was the Controller PCB. Once if I remember it was a bad memory DIMM.
          Good luck and follow the RTB if you have access to it
          "Heavy music to the normal ear is nothing but a loud annoyance. Most people think of it as obnoxious, talentless music but to someone who really listens and is really in love with music knows how beautiful and amazing it can be" Tommy Rogers of Between The Buried and Me"
            • 37532
            I had one about a month ago. Complete power down, unplug from the wall, took the back off and reseated the USB cable for the operation panel at the frame side end.
            • kannuki2
              • Feb 2012
              • 398
              I'd try to reseat the IPU connection to the controller. I had similar issue on a mpc8002 and had to replaced a controller + op panel as a set.
              • BLADE
                former propeller tester
                • 478
                the main problem is the fault code itself is inaccurate
                • Imprestik
                  • Aug 2012
                  • 297
                  Guys this is a known fault from the factory.
                  The egg heads building these devices have cable tied the USB cable and harness which runs from the Op Panel to the IPU way too tight which break the USB cable
                  If you ever get a SC672-11 or SC672-12 on these devices, turn them off immediately and go to a computer shop and buy a USB to micro USB cable, male to male I think.
                  Disconnect the cable and tuck it away neatly in the cavity, dont bother removing it, takes too much time and effort and run the new cable through the cavity (just follow the old USB cable)
                  If you get it early enough it will only be the USB cable, if not your in for a controller as well
                  I have lost count how many USB cables I have replaced on the Metis
