Unable to save SMB detination to an MPC 2050
  • Codex
    • May 2008
    • 705
    Hello
    I have a strange problem with a MPC 2050, the customer changes OS, and called to setup scan2folder again (before the OS change everything worked fine).I made an Firmware update for Win10 , and starts to setup the destination, everything worked, but if i try to save the destination the message "unable to save" appears.
    Any ideas???
    Memento Audere Semper
  • copyaction
    • Oct 2007
    • 991
    Re: Unable to save SMB detination to an MPC 2050
    Have you tried using a different browser?
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3944
      Is your address book already full?
      • gkalman2004
        • 157
        Back up the address book data and Initialize the address book data (SP5-846-046) and the user
        information. (Restore the address book data if possible.)
        Try maybe help 5846-041 (is for new hdd but maybe work for you)
        • Codex
          • May 2008
          • 705
          I tried only from the op panel.. Not with wim... The adress book is empty (hdd formatted)..
          Inviato dal mio SM-G935F utilizzando Tapatalk
          • gkalman2004
            • 157
            SP5846-041
            This SP must be executed immediately after installation of an HDD unit in a basic machine
            that previously had no HDD. The first time the machine is powered on with the new HDD
            installed, the system automatically takes the address book from the NVRAM and writes it
            onto the new HDD. However, the new address book on the HDD can be accessed only
            by the system administrator at this stage. Executing this SP by the service technician
            immediately after power on grants full address book access to all users.
            Procedure
            1. Turn the machine off.
            2. Install a new HDD.
            3. Turn the machine on.
            4. The address book and its initial data are created on the HDD automatically.
            5. However, at this point the address book can be accessed by only the system
            administrator or key operator.
            6. Enter the SP mode and do SP5846-041. After this SP executes successfully, any user
            can access the address book.
            • Codex
              • May 2008
              • 705
              Thx... I'll try this way
              • Dark Helmet
                • May 2009
                • 867
                Once your able to save the destination one thing to check on windows 10 for scanning that can be a real pain.
                In the taskbar click the network icon, click the picture of the computer/network, (not network settings). Then you should see another picture of a computer/network cable, click that one and turn on "MAKE THIS PC DISCOVERABLE".
